nhatey
Feb 11, 2022Aspirant
High ping to local router (Nighthawk ac1900 R7000)
I've suddenly gotten high ping. Router was working fine and was stable since October. When pinging via CMD : ping 192.168.1.1 -t on both 2.4 and 5ghz I find the ping to spike a lot going from 1...
nhatey
High ping is on all devices. Firmware is up to date, just checked last night
Feb 11, 2022Guru - Experienced User
what actual firmware are you on?
the R7000 is knowns for saying "up to day" when its not.
what modem are you using?
- nhateyFeb 11, 2022Aspirant
Modem is CM500, Firmware is Version V1.0.11.100_10.2.100
Here is a sample log of the high ping
Pinging 192.168.1.1 with 32 bytes of data
Reply from 192.168.1.1: bytes=32 time=15ms TTL=64
Reply from 192.168.1.1: bytes=32 time=98ms TTL=64
Reply from 192.168.1.1: bytes=32 time=130ms TTL=64
Reply from 192.168.1.1: bytes=32 time=78ms TTL=64
Reply from 192.168.1.1: bytes=32 time=112ms TTL=64
Reply from 192.168.1.1: bytes=32 time=193ms TTL=64
Reply from 192.168.1.1: bytes=32 time=188ms TTL=64
Reply from 192.168.1.1: bytes=32 time=9ms TTL=64
Reply from 192.168.1.1: bytes=32 time=34ms TTL=64
Reply from 192.168.1.1: bytes=32 time=29ms TTL=64
Reply from 192.168.1.1: bytes=32 time=241ms TTL=64
Reply from 192.168.1.1: bytes=32 time=11ms TTL=64
Reply from 192.168.1.1: bytes=32 time=37ms TTL=64
Reply from 192.168.1.1: bytes=32 time=91ms TTL=64
Reply from 192.168.1.1: bytes=32 time=280ms TTL=64- plemansFeb 11, 2022Guru - Experienced User
the latest firmware is currently 1.0.11.130.
Try installing that, doing a factory reset, and reinstall.
