davidlwoolard
Oct 18, 2021Follower
hooking up 2 routers Netgear RAX4 and Netgear AC3200
I have both of these routers and would like to hook both of these up on the same network (Spectrum Internet) due to distance from the first router to the AC3200. RAX40 is the primary, AC3200 will be...
Oct 18, 2021Guru - Experienced User
did you install the AC3200 (hint, thats its speed, not model) in access point mode?
Otherwise it causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
