Noargos's avatar
Noargos
Hoping to use Nighthawk AC1900 C7000 as an extension router From an ATT DSL modem/router
After using my Nighthawk AC1900 in a Cable Modem environment, I recently changed internet service/TV providers and the new one ATT Uverse utilizes a PACE Model 5268 AC (DSL). It is my hope to use pe...
  • antinode's avatar
    antinode
    Jul 05, 2020
    > There is such a thing as a coax / cat5 adapter, but they are not cheap
    > (~$100) and they may not allow the same speeds.
       I would not expect any such adapter to be useful in this situation.
    > [...] use the Netgear in Bridge / extender modes [...]
       Does a Cxxxx have such modes?  Documentation?
    > [...] you can use a cat5 cable right from the 5268 to the input port
    > on the Netgear using an adapter and then use that as your primary.
       This is nonsense.  First, all ports on these devices are
    bidirectional; there are no "inputs" or "outputs".
       Second, a Cxxxx modem+router is expecting its co-axial cable
    connector to be connected to a cable-TV-type ISP.  Any adapter (modem)
    which simply converts twisted-pair Ethernet signals to/from co-axial
    cable signals will not magically convert a Cxxxx into an Rxxxx.
    > Google "cat5 to coax network adapter" to see what options you have.
       Complete waste of time and effort.  (And money, if you buy anything.)
