ferseb's avatar
ferseb
Follower
Oct 08, 2021
hot fix
The latest firmware release to my router is a 'hotfix' but i do not have the release before that. Should i install the release of the firmware before and then the hotix release or just go right onto ...
  • FURRYe38's avatar
    Oct 08, 2021
    You can go right to the hotfix if you want too. You don't have to apply other versions first.
