Smile43
Dec 22, 2019Aspirant
Hotfix 1.1.0.92
Today I received an email from Netgear saying I should install this 'security update'. When I try to do so using my router's browser interface, it says there are no updates available. I am currentl...
- Dec 23, 2019
A hotfix is firmware that may or may not make it into a final version.
If you look at the release notes you should see a clue as to what it does.
It may be something trivial that you can ignore.
Those mailings are standard Netgear practice. Think of them as marketing messages. They usually have not much to do with any recent firmware update for your hardware. Netgear just presses a "send " button from time to time and splatters the planet with email messages.
michaelkenward
Dec 23, 2019Guru - Experienced User
Smile43
Dec 24, 2019Aspirant
Thank you!
