dgennen
Dec 27, 2021Follower
How can I activate the wifi ac1600 with the Nighthawk app?
We are having difficulity getting our Netgear wifi 5 AC1600 Router set up. First of all, there are not enough instructions to get the router up and running. Do we start with the Nighthawk app? Isn...
Dec 27, 2021Guru - Experienced User
what actual model do you have? AC1600 is a speed, not a model.
And the setup could be different if you have a modem/router combo device verses just a router.
There's a support site with access to manuals, firmware, install guides for installing with more than 1 route.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
