Amitky7
Mar 19, 2021Follower
How can I use Nighthawk AC1900 (C7000) as Wifi extender with Google Nest as primary router?
Mar 19, 2021Guru - Experienced User
Not as an extender but you can make it run as a form of access point. But it'd need to be hardwired in.
this guide goes over it for a c6300 but it should be similar for the c7000
Can I use a C6300 cable modem without cable intern... - NETGEAR Communities
