ibslim21
Nov 25, 2021Aspirant
How Disable SIP ALP Netgear NightHawk M1
Hello i read many informations about disable SIP ALG is it really possible to disable SIP ALG for Netgeagear Nighthawk M1 ? or do i have to buy a an other NightHawk M2 ? thanks and bests reg...
- Nov 26, 2021
Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with mobile routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
Thank you
Nov 26, 2021Guru - Experienced User
Thank you
- ibslim21Nov 27, 2021Aspirant
Thanks very much it try to transfert the question at the good place.
bests regrads
