Gar2019
Aug 25, 2022Aspirant
How do I change a device name on my network? R8000
It looks like I should be able to change the device name to something meaningful for devices that are not named by the router. In Netgear Genie, I can change the names but they don't stick. Using N...
Aug 25, 2022Guru - Experienced User
Try setting up a IP address reservatoin for the device then edit the name here before saving the setting then applying the change using a PC and web browser on the routers web page under advanced tab/Setup/Lan Setup?
