Dumb-dumb
May 27, 2018Aspirant
How do I change my WiFi Password
I have had my router for six months now. The router works great. I originally changed the network name and password. Now I want to change only the network password again. I am having issues figuring o...
- May 29, 2018
Dumb-dumb wrote:
I appreciate the response. The firmware is 1.0.9.26
I did get into a password recovery area, but after answering the 2 security questions it doens't give me an option to hit continue.
Usually when you can't see a control like a button it is clearly BROWSER related. I'd try it again with a different browser.
Look https://kb.netgear.com/24220/How-do-I-recover-my-password-on-my-Nighthawk-router for NG details on how to do this.
Dumb-dumb wrote:
I have tried admin and password, but that doesn't work. I have also tried using the router label and that isn't working either.
This is definitely frustrating. Any other ideas?
Had you CHANGED either before? If so, you must use those. Make sure the CAPS key isn't on and if you had a Capital letter then use it. Case matters here.
Still doesn't work. Router RESET is the way to go, https://www.router-reset.com/30-30-30-reset-factory-defaults-wireless-router/. That should put you back to NO SETTINGS in the router and you should be able to login with the UID and PW on the router label.
Dumb-dumb
May 29, 2018Aspirant
Initially I wanted to only change my WiFi password, but now I want to check out the router's control interface as well and make sure that the remote management option is not enabled.
For routerlogin.net what is the interface password? I am connected via WiFi now.
I appreciate your time and energy!
antinode
May 29, 2018Guru
> [...] Initially I wanted to only change my WiFi password, but now I
> want to check out the router's control interface [...]
Have you considered the advantages of fetching a copy of the R7000
User Manual, and doing some reading?
Covered on page 19, "Log In to the Router". See also page 17, "Types
of Logins". When in doubt, visit http://netgear.com/support , put in
your model number, and look for Documentation. Get the User Manual (or
for older products, something similarly named).
Shouldn't matter.
You could probably consume less of it by reading the User Manual.
