elvislennon1242's avatar
May 16, 2021
How do I change my wireless network password Netgear?
If a user is unable to log in to the routerlogin.net window, the first thing he should check is the login credentials that he typed on the Netgear router login window. The default username is “admin” and the default login password is “password” of the login window of a Netgear router. Make sure you hold the Shift key when you want to type an uppercase letter and release the shift key when you want to type a lowercase letter. Any fault while typing the login password may bring failure in the login process.
No RepliesBe the first to reply
