Newbie1966's avatar
Newbie1966
Follower
Jan 02, 2022
How do i connect to my current network
1 Reply
  • FURRYe38's avatar
    More details like what NG router model do you have and what mobile device you have would be helpful.
    To get a hold of support. Click on "MyNetgear" at the top.
    Register an account (or login) and then the device.
    From there you can start the support process. Keep in mind that its only free for the first 90 days.
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
