Sailordude9980
Jul 18, 2016Aspirant
How do I deploy a VPN to my home network?
Good Morning Netgear Community I am setting up a VPN for the first time on my home network. I have a question about deploying the VPN service to other devices on my network. Can I setup Open V...
- Oct 20, 2016
Yes you need to configure your router to run VPN on any device. Here's a simple guide for you https://www.purevpn.com/router-vpn.php
Retired_Member
Jul 18, 2016The help menu pulldown in the router suggest (to me anyway) it's required on any device which will be used to remote in not each device on the local LAN.
