lilsplrge's avatar
lilsplrge
Follower
Dec 20, 2021
how do i determin my password for my nighthawk modem/router
i need to change the pawword on my nighthawk ac1900 modem/router due to a hack...how would i go about it ?
1 Reply
  • plemans's avatar
    You could simple factory reset it and start back from stock. Then you can change you login info and ssid/password.
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
