joelsantiago's avatar
Jul 19, 2016
How do I disable automatic IP address updating (when conflict is detected with ISP)?
  I use a non-routing range on my LAN and use static IP addresses for certain hosts. The automatic change accompanied by:   Important Update To avoid conflict with your Internet Service Provider,...
  • TheEther's avatar
    TheEther
    Jul 20, 2016
    You may not like the automatic changing of IP addresses, but the behavior is a sign that your LAN and WAN subnets conflict with each other.  I don't know how your other router was able to work correctly with such a conflict, but you should fix it.  For example, if your ISP is using subnet 192.168.1.0/255.255.255.0, then set your LAN to use 192.168.2.0/255.255.255.0.  Problem solved.
