hbk_seanmichael
May 27, 2021Aspirant
How do I disable DHCP on my AP router?
I have an R7000 as my main router connect to the ONT/Modem. I have an ethernet cord going from the LAN of R7000 to the WAN of the R7000P. The R7000P is in AP mode. The main router (R7000) has wifi d...
antinode
May 27, 2021Guru
> R7000P is in AP mode. The main router (R7000) has wifi disabled.
Then what's the point of using both the R7000 and the R7000P? Are
other client devices connected to the R7000? If not, then what's the
R7000 doing for you which the R7000P couldn't do by itself?
How, exactly, did you configure the R7000P "in AP mode"? Did you
follow the procedure in the R7000P User Manual under "Use the Router as
a WiFi Access Point", or some other scheme (namely?)?
> [...] I cant seem to find where to turn DHCP off on the R7000P. Here
> is images of the connection. [...]
Plenty of context missing from those pictures.
Using ADVANCED > Advanced Setup > Router / AP / Bridge Mode : AP Mode
should disable the DHCP server as part of the "AP Mode" configuration.
I don't have an R7000P, so I can't test it, and so I know nothing,
but it's possible that the "DHCP On" status which you're seeing in that
"LAN Port" status report is erroneous/misleading. It might reflect what
would be true if the R7000P were in full-function Router mode, but be
meaningless in any other mode.
> [...] Should I just disable the DHCP on the R7000 since i dont even
> have wifi active on it???
No. The real mystery here is why the R7000 is involved in the first
place. If you're using the R7000 as a router, with the R7000P as a WAP,
then you'd want a DHCP server someplace, and, when configured as a WAP,
the R7000P won't be doing that job. That leaves only the R7000 to be
your DHCP server.
Disabling the wireless-network radios in the R7000 does not stop it
from being a router.
Are you seeing any actual operational problems, or is "DHCP On" your
only complaint? If you really did have multiple (uncoordinated) DHCP
servers running on your LAN, _then_ I'd expect to see abundant problems
caused by IP-address conflicts.
> You haven't set your R7000P in proper Access Point mode, then
Or, as I claim, the report is misleading.
> If AP is active, your main router (R7000) should assign an IP to it,
Like, say, "192.168.1.2", as shown in that "LAN Port" status
report in the picture? Seems (to me) to be working as expected.
Lacking any report to the contrary, I believe that the R7000 is
acting as a router (with an active DHCP server), and the R7000P is
acting as a WAP (without an active DHCP server), and everything is fine,
except for that misleading "LAN Port" status report.
The only remaining mystery is what value the R7000 is adding to this
equipment pile.
antinode
May 27, 2021Guru
> [...] I set a static IP [address] of 192.168.1.2 for the R7000P from
> the r7000 interface.
Terminology: A "static" address is configured on the device itself.
What you configure on a (DHCP server on a) router is a reserved dynamic
address, not a static address. Either one should fix the address of a
device, but some implications are different.
That sounds as if you were following the User Manual, and chose the
default, "Get dynamically from existing router." (Note, "dynamically",
not "static". "Use fixed IP settings on this device (not recommended)"
is how you tell it to use a static LAN IP address, which you'd configure
manually under ADVANCED > Setup > LAN Setup : LAN TCP/IP Setup : ...)
My conclusions remain unchanged (but I'm always open to actual
evidence, or a good counter-argument).
