hbk_seanmichael
May 27, 2021Aspirant
How do I disable DHCP on my AP router?
I have an R7000 as my main router connect to the ONT/Modem. I have an ethernet cord going from the LAN of R7000 to the WAN of the R7000P. The R7000P is in AP mode. The main router (R7000) has wifi d...
hbk_seanmichael
3500 sq ft house. The utility room upstairs Is where the builder ran all the fiber to. So the ONT is in there with the r7000. Wifi signal was weak in most of the house. So I disabled the wifi on the R7000 and I ran ethernet from LAN1 of R7000 down to the laundry room which is smack in the middle of the house. Hooked it up to WAN R7000P which I then setup in AP mode. LAN2 on R7000 runs to my Xbox downstairs. LAN3 to my office and LAN4 to the master bedroom.
antinode
May 27, 2021Guru
> [...] LAN2 on R7000 runs to my Xbox [...]
Good enough for me; the R7000 has an actual purpose in life.
> Are you seeing any actual operational problems, [...]
If not, then my advice remains: "Don't worry; be happy."
