MrSmoofy
Nov 15, 2024Aspirant
How do i get around ERR_SSL_KEY_USAGE_INCOMPATIBLE
This site can’t be reached The webpage at https://192.168.1.1/ might be temporarily down or it may have moved permanently to a new web address. ERR_SSL_KEY_USAGE_INCOMPATIBLE Anyway to get a...
michaelkenward
Nov 16, 2024Guru - Experienced User
Have you tried routerlogin.net?
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
If there is one it might help if you told people the make and model number of the modem/gateway/ONT that connects this router to the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
Having two routers on a network can cause headaches. For example, you can end up with local address problems.
For example, seeing a router upstream your R6700 may have squatted on a different default IP address. It may use 10.0.0.1 as a fallback.
There is another possible cause of what you see, if you check "Always use HTTPS" in Web Services Management. It won't let you in.
This is all guesswork on my part. Your description is very thing on details of what you are actually doing. So I may be wrong. If none of that rings any bells, come back with more details of what you are doing and where it goes wrong.
Just another user with time on their hands.
