MrSmoofy
Nov 15, 2024Aspirant
How do i get around ERR_SSL_KEY_USAGE_INCOMPATIBLE
This site can’t be reached The webpage at https://192.168.1.1/ might be temporarily down or it may have moved permanently to a new web address. ERR_SSL_KEY_USAGE_INCOMPATIBLE Anyway to get a...
MrSmoofy
Nov 16, 2024Aspirant
It's the only router and the only thing in front is a Spectrum Cable Modem which is not a router at all. I'm dealing with a DOS and Spectrum is unhelpful so I was trying to lock things down. I enabled VPN and got that working and then did enable "Always use HTTPS" and I'm guessing that is what the problem is.
The DOS is still going on but I'm not home as I'm recovering from surgery and won't be home for a couple of months. While I can RDP still to the PC's on the network the DOS is causing problems and my end goal was enable VPN and turn off all port forwarding, enable remote management (hense use HTTPS) and block all IP traffic inbound from Russia and Netherlands where the DOS is coming from.
Was hoping to find a solution outside of factory reset which I can't do until I'm home again.
michaelkenward
Nov 17, 2024Guru - Experienced User
Aha! It always helps to go back to the original problem. In your experiments you have made changes that won't deal with it, but that can lead to the problems you experienced.
Netgear's firmware is great at creating false reports of DoS attacks. Many of them are no such thing.
Search - NETGEAR Communities – DoS attacks
Use Whois.net to see who is behind some of them and you may find that they are from places like Facebook, Google, even your ISP.
Here is a useful tool for that task:
IPNetInfo: Retrieve IP Address Information from WHOIS servers
If these events are slowing down your router, that may be because it is using up processor time as it writes the events to your logs. Anything that uses processor power – event logging, QoS management, traffic metering – can cause slowdowns. Disable logging of DoS attacks and see if that reduces the problem. This does not prevent the router from protecting you from the outside world.
In the case of your R6700, this is an ageing (2014) router that is several generations behind the latest network technology. Netgear also isn't likely to provide updates. It is "EOS":
NETGEAR End of Service | NETGEAR
Just another user with time on their hands.
- MrSmoofyNov 17, 2024Aspirant
While I appreciate you responding you have done nothing to actually help with my issue which is the SSL error when trying to browse to the router portal. I don't need all the other info you have told me I already know all this. I know it's a DOS because i can see the login attempts on my forwarded ip addresses that are using none standard ports. I've had this router configured this way for over 4 years and never had a problem with this. The turning on of using HTTPS has blocked me from logging in, so do you know of a solution other then factory resetting the router or not?
- michaelkenwardNov 17, 2024Guru - Experienced User
I'm puzzled. Haven't you acknowledged that already?
and
The turning on of using HTTPS has blocked me from logging in, so do you know of a solution other then factory resetting the router or not?Have you now changed the problem? You want to be able to turn off "Always use HTTPS" without a reset?
That's not what you asked.
Sadly, there are times when someone has made such a dog's dinner of their settings that a reset is the only way out. Doubtless you already have a backup of your earlier settings that you can restore from before you unwisely made that change.
I am a bit puzzled by the bit in your first message I've tried the Registry entries but didn't work. Where the heck did that come from? Why would anyone mess around there when trying to fix a router?
The issue I stated in the original post. I'm not sure why you have such a hard time understanding this.
ERR_SSL_KEY_USAGE_INCOMPATIBLEThis is likely because I enabled HTTPS on the router. When searching for a solution I found posted in the Netgear community someone suggested to make some registry changes to get around this but that didn't work. So I'm looking for a solution other then factory resetting the router.
