bdlabar
Dec 06, 2021Guide
How do I increase the speed on my R6080
Dec 07, 2021Guru - Experienced User
A couple things.
1. You're right in that you'll need to upgrade the router to hit 100mbps+ speeds. The bottleneck in the R6080 is its 10/100mbps connections.
2. 200mbps is a decent speed. don't expect to hit 200mbps over 2.4ghz on your devices. 5ghz should but the 2.4ghz band is a slow band and is sensitive to interference.
3. when looking at routers, you don't need "the best" but you do want more than a base model devices. With you already having 200mbps, I'd make sure to get a half decent router so you've got a little future proofing.
bdlabar
Dec 07, 2021Guide
I just ordered a night hawk ax1800 2 pack it should be fine for my use
- plemansDec 07, 2021Guru - Experienced User
The MK system? if so, it definitely should!
If you have problems just let us know and we'll be happy to help.
(there's a different forum for the MK system so the people with more experience can help with it)
