SweetMsJ
Jul 07, 2019Aspirant
How do I make my network name is invisible?
How do I make my network name invisible? I live in a high-rise and there are already 25 or so names to choose from for my Wi-Fi service, but I would rather keep mine from being displayed to all my n...
- Jul 07, 2019
Most folks want to hide their ssid so others do not see it thinking this is a security step. Here is article saying not so.
Also, hiding the SSID can cause MS Windows issues as well as general connection issues.
antinode
Jul 07, 2019Guru
> Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Presumably, you have some other device, like an R7000 router.
> [...] I have looked in the user manual PDF, but I can't find a topic
> that I think would answer my problem.
Under "Specify Basic WiFi Settings", look for "Enable SSID
Broadcast".
SweetMsJ
Very interesting. When I tried making the setting changes, I got a warning that I was about to disable all my WPA settings. I decided perhaps it was better to keep those settings then to go invisible.
The other big mystery was I could only access the 2.4 GHz SS ID. I only use that for the printer. But now I’m wondering how I would go about accessing the other band. Perhaps I would have to log on using the 2.4 SS ID in order to make changes.
Thank you very much, antinode, for your help. I didn’t realize what the ramifications of the choice not to broadcast the SS ID were. This is why newbies get them selves into so much trouble.
- myerswJul 07, 2019Master
- SweetMsJJul 07, 2019Aspirant
Bill, if it’s one thing I don’t want, it’s complications.
Thank you for the article link. That was the very same argument that occurred to me when I saw the warning — why would I want to forgo the security for anonymity. I feel like I did the right thing, and I really appreciate the confirmation.
The issue was solved – thanks to you both.
- antinodeJul 07, 2019Guru
> about to disable all my WPA settings.As usual, showing the actual error message would be more helpful than
showing your interpretation of the actual error message. Copy+paste is
your friend. This is especially true when you've misread the message,
which, I'd guess looked much like the one which I get on my D7000
(V1.0.1.70_1.0.1):WPS requires SSID broadcasting in order to work. If you make this
change, WPS will become inaccessible. Do you want to continue?"WPS" and "WPA" are spelled differently for a reason.
> [...] I decided perhaps it was better to keep those settings then to
> go invisible.Keeping WPA enabled makes sense. WPS is up to you, but an informed
decision depends on noticing that WPS is not WPA. Keep reading that
User Manual.> [...] I could only access the 2.4 GHz SS ID. I only use that for the
> printer. [...]"access" from what? What is your "the printer"? Are you trying to
say that your (unspecified) "the printer" can use only the 2.4GHz radio?
Such a limitation would be typical for a printer (which typically would
not benefit from faster network access).
> [...] why would I want to forgo the security for anonymity. [...]You probably wouldn't, but that's not the choice here.
> [...] Here is article saying not so. [...]
It's extremely easy to find the ID for a "hidden" network-all you
have to do is use a utility like inSSIDer, NetStumbler, or Kismet
to scan the network [...]Quiz questions: Do you use any of those programs? How many of your
neighbors, would you guess, use any of those programs?Hiding your SSID(s) will not hide your wireless radios from a
determined attacker, but it will hide them from, I'd guess, most if not
all of your neighbors. And it won't cause you to forgo any security.
- ellengriz01Aug 07, 2019Aspirant
