dickclark7
Jul 06, 2018Follower
HOW DO I make my router a repeater
I iwould like to make my Router a repeater so that I can utilize the older equipment to extend my network reception in my home. I need detailed instructions on how to do this.
- microchip8Master
you don't really want to do that. A better way is to use (multiple) access points connected to the router. Repeater will cut you wifi speed in half as it needs to be in constant contact back and forth with the main router it is repeating the signal of
- microchip
I have x 2Night hawk x7000 AC1900 RANGe
Extenders in RANGE extend mode.
If I hardwired these back to my router Night hawk x6 r8000 ac3200 and changed them to ACCESS POINTS should I get full bandwidth like I do when I do speed test right beside the router? Do they have the same wifi signal /power as a router like my x6 tri band router?- microchip8Master
In short, yes. The only downside of access points is, as you mentioned, you need to pull a cable. I've seen a lot of people that simply can't so their only option is either repeaters or powerline adapters
