Belden79
Jun 11, 2021Follower
How do i reconnect my extender after i change my wifi password
1 Reply
simply factory reset it and then follow the install guide.
to reset, push and hold reset for 7-15 seconds while its powered on.You can find the install guide at netgear.com/support/ type in your model number and it'll take you to guide, firmware, and manuals.
