ESILVER
May 16, 2019Initiate
How do I roll back to a previous firmware?
 Where do I find the firmware file to rollback to and how can I see what my previous version was?
 Thanks in advance.
- May 16, 2019
Quite EASY... on the top, click on SUPPORT. Then enter your ROUTER model, R700 and click on the proper model that shows and press enter. Next screen, click on DOWNLOADS. At the end of the list is PRIOR VERSIONS. One the one you want you see a '+'. Click on that and there are TWO links. Click on the README and just FOLLOW those instructions.
IrvSp
May 16, 2019Master
ESILVER
Perfect. Thanks.
