Ana2
Jun 15, 2021Aspirant
How do I setup a bridge mode on the NETGEAR R7000?
Based on the instruction that came with my Netgear Nighthawk R7000 AC1900 Smart WiFi Router, I disconnected the router provided by my cable company and replaced it with my Netgear router. Although t...
Ana2
Jun 16, 2021Aspirant
I followed the manufacturer's instructions that came in the box with the new router. I am using the cable company's modem but replaced their WiFi router with my Netgear 36 nighthawk R7000 router. It worked fine for a while but now my internet connection keeps dropping. After reading the various related issues other users had it seemed like I needed to create a bridge. Based on your feedbacks and since it is a new router I will be contacting their support group. Thank you all for your support.
antinode
Jun 16, 2021Guru
> the new router. [...]
With my weak psychic powers, I can't see them from here. Thus, I
don't know what you read, or what you did.
> [...] I am using the cable company's modem [...]
With my weak psychic powers, I can't see it from here. Has it a
maker and model number?
> [...] but replaced their WiFi router [...]
> like I needed to create a bridge. [...]
With my weak psychic powers, I can't see what you read. "seemed"?
> What, exactly, led you to that conclusion? What, exactly, does
> "set up a bridge" mean to you?
Which part of "exactly" did you find confusing?
Thanks for answering none of the questions.
> [...] Based on your feedbacks and since it is a new router I will be
> contacting their support group. [...]
You might need to provide some useful information, there, too.
