JazzyJazz's avatar
JazzyJazz
How do i setup r7000 to switch between vpn and local isp?
I currently have my router flashed with DD-WRT v3.0-r30800M kongac (10/27/16) for several months. However, I need to now be able to switch between having a vpn connection and my local isp. I haven't ...
  • ElaineM's avatar
    Jan 10, 2017
    Welcome to the community JazzyJazz
    You are looking for a split tunneling feature.
    Check if your DD-WRT firmware supports it.
