JazzyJazz
Jan 05, 2017Aspirant
How do i setup r7000 to switch between vpn and local isp?
I currently have my router flashed with DD-WRT v3.0-r30800M kongac (10/27/16) for several months. However, I need to now be able to switch between having a vpn connection and my local isp. I haven't ...
ElaineM
Jan 10, 2017NETGEAR Employee Retired
Welcome to the community JazzyJazz
You are looking for a split tunneling feature.
Check if your DD-WRT firmware supports it.
JazzyJazz
Jan 10, 2017Aspirant
Hi Elaine,
Thanx for your response. I will certainly look into this. For now, I found a work around in which I am able to use my cell phone data for the sites I can't access due to using my vpn. I love dd-wrt so I don't want to part with it and I'll be sure to look into the split tunneling feature. I also love netgear! Slightly indirectly related compliment to Netgear, I just received my Netgear CM 1000 modem and I love it!
