opses0
Mar 02, 2021Tutor
How do I turn the wireless signal back on during scheduled off time?
I've set up my scheduled wifi hours, but was wondering how to override if I need to turn it back on?
antinode
Mar 11, 2021Guru
> I woke up before 6:00 am and could not access my router to reschedule
> or turn my wifi back on.
"Doctor, it hurts when I do this."
"Don't do that."
Use a computer with a wired connection to reverse your careless
decision?
Settings reset, and reconfiguration? You could keep around a
configuration file without the schedule for such emergencies.
opses0
Mar 12, 2021Tutor
Well, you could have just answered my question rather than being sarcastic.
The answer is, you can't change the settings using wifi during the scheduled off time. Use your phone to change the settings. There is no override button on the router.
Thanks for the trouble.
