Sdg1
Dec 11, 2021Follower
how do i update my smart wifi netgear 6250 router
How do i update my smart wifi router model number 6250
Dec 11, 2021Guru - Experienced User
What model do you have?
there's an R6250 and a C6250.
the R series can be updated by the end user.
The C series, the firmware is part of the partitioning from the ISP.
So its kind of key to know what version you have to see if you can update.
