darkqueman's avatar
darkqueman
Follower
Sep 20, 2021
How do I use Netgear R400 with Armour sub to 2022 behind Fios G3100 without double natting?
is there a way I can use my fios G3100 router as my primary router but point my network to use netgear armour without double natting my network. How you i make such a connection. Need to use my fios ...
  • plemans's avatar
    Sep 20, 2021
    No there isn't a way have the both.
    You can connect the netgear to the G3100 and put the netgears IP address into the G3100's DMZ.
    That'll fix the double nat tof the netgear and any device connected to the netgear can be protected by Armor.
    But there isn't a way for armor to function on the G3100 or the devices directly connected to the g3100
