KevinAZ
Aug 29, 2021Aspirant
How do Install my VPN on Netgear router?
Hello, My model was not listed in the drop down list. I have the Nighthawk AX6 AX4300 router and am trying to install my IPvanish I can't find any directions anywhere. Any help would be greatly appr...
KevinAZ
Aug 30, 2021Aspirant
I apologize, my main router I'm trying to setup IPvanish VPN on is C7800|Nighthawk X4S-AC3200. Does anyone know if this is possible?
Thanks
I also have the RAX45 which I guess runs the Armor VPN.
- plemansAug 30, 2021Guru - Experienced User
No you can't install IPvanish on the C7800 or the RAX45.
IPvanish has a list of routers on their site they support.
https://www.ipvanish.com/vpn-setup/routers/#routers-setup
Neither of those routers is on there. IPvanish is 3rd party firmware. You'd have to ask them if they'll ever support the RAX devices.
The C7800 is a modem/router combo device and the firmware is locked by the ISP.
- KevinAZAug 30, 2021Aspirant
Many thanks, I appreciate the help.
