gobananasnet
Oct 12, 2021Apprentice
How do you update the RBS750 Satellite firmware from the Orbi app?
How do you update the RBS750 Satellite firmware from the app (NOT the web portal 192.168.1.1)? The router is an easy process, but not the satellite. Thanks
- Oct 16, 2021
Try admin and password?
Oct 13, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Has to be updated on the RBS web page itself or from the RBRs web page.
Thank you.
- plemansOct 13, 2021Guru - Experienced User
Here's how.
https://kb.netgear.com/000058278/How-do-I-update-the-firmware-of-my-Orbi-WiFi-System
I wouldn't recommend it though. Reason why is that when we see corrupt firmware issues, it tends to be when people updated over wifi or when using the app. For the most part it works great but again, when we see issues, thats usually how it was updated.
- FURRYe38Oct 13, 2021Guru - Experienced User
I find manually updatng Orbi systems is the best way:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite- gobananasnetOct 13, 2021Apprentice
When I try to do the manual method it does not like the 192.168.1.2 password and I can't seem to find a way to change it. Plus this is the odd thing as I see one satellite updated and the other did not (shown below). It's weird. What do you make of this?
