gobananasnet
Oct 12, 2021Apprentice
How do you update the RBS750 Satellite firmware from the Orbi app?
How do you update the RBS750 Satellite firmware from the app (NOT the web portal 192.168.1.1)? The router is an easy process, but not the satellite. Thanks
- Oct 16, 2021
Try admin and password?
Oct 16, 2021Guru - Experienced User
the username/password for the satellite should be the same as the one to log into the router.
gobananasnet
Oct 16, 2021Apprentice
Yes, I've tried that, yet nothing happens. I click the button and the two fields go empty and no error message or anything. Nothing happens. Ugh!
- FURRYe38Oct 16, 2021Guru - Experienced User
- gobananasnetOct 16, 2021Apprentice
Thanks! That worked. Why it did not use the Router log-in and password is odd. Satellite is now updated. Thanks again.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-SystemBe sure to visit the Orbi AX forum for you future support and information needs.
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/bd-p/en-home-orbi-ax
Enjoy. 📡
