taki7
Mar 13, 2023Follower
How do you Whitelist, add IP address- Netgear 7550
How do I whitelist a set of IP addresses given by my PCI compliance company so they can run the ASV scans. I was told I need to add the 2 IP addresses they gave me to the "allow" list on my modem set...
michaelkenward
Mar 15, 2023Guru - Experienced User
taki7 wrote:
I have a Netgear 7550.
That's not a Netgear model I can find in the system. Do you mean R7500?
Look at the label in the thing.
What's ASV? Whitelist for what?
Below are the pictures from my modem settings.
Modem settings? The R7500 is a router. If there is a modem on your network, tell people what make and model it is.
PS Alt+ Print Screen beats pointing a camera at a computer screen.
