grwsmith
Jun 15, 2015Tutor
How I can change the Username itself, not just the password.
Hello, How I can change the Username itself, not just the password please? Cheers, Guy.
- Jun 16, 2015Are you referring to the username and password of the UI? If that's the case, you cannot change the username as there is no option for you to change it.
alexthefool
Jun 24, 2015Aspirant
I hope we can do that in the coming firmware.....
Frankly, no need to try the username is half the way to crack in the router.
