grwsmith
Jun 15, 2015Tutor
How I can change the Username itself, not just the password.
Hello, How I can change the Username itself, not just the password please? Cheers, Guy.
- Jun 16, 2015Are you referring to the username and password of the UI? If that's the case, you cannot change the username as there is no option for you to change it.
fordem
Jun 30, 2015Mentor
Babylon5 wrote:
At work I use Cisco routers costing thousands of pounds, they have no admin ID either, they only prompt for a password, no mention of a User ID.
You can, if you so choose, create users, with different levels of access on most Cisco IOS versions, and almost every installation I have seen will only allow access without a userID from the console - for security reasons.
