salwameshum
Nov 23, 2021Follower
How I can change the wireless channel on NETGEAR router?
Hello dear community, How I can switch wireless channel on the Netgear Router..?
Nov 23, 2021Guru - Experienced User
https://kb.netgear.com/23783/How-do-I-change-the-wireless-channel-on-my-NETGEAR-router
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
