BarbSki
Oct 25, 2021Tutor
How I power off my Nighthawk CAX30? Can't find on/off button
Item 2 on page 15 of the User Manual, it says "Press the On/Off button on rear panel" I can not find a on/off button on the rear panel. The picture of the rear panel on page 13 is exactly what my m...
BarbSki
Oct 25, 2021Tutor
Okay. Thank you!
Oct 26, 2021Guru - Experienced User
For your future needs, Netgear has set up a community forum specifically for the Orbi With Cable Modem products. Most of the people who watch that forum are more likely to have experience with Orbi with cable modem and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
Thank you.
- BarbSkiOct 26, 2021Tutor
Thank you for the information. I don't have an Orbi. I have a stand-alone cable modem router, but if that's a better category for my modem router questions, I will definitely post in that section.
- FURRYe38Oct 27, 2021Guru - Experienced User
Sorry about that, my bad. Posted incorrect information. :smileyembarrassed:
Please post here:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
