rkruz
Feb 24, 2022Apprentice
How ID device from IP address?
Im interested to know what devices are on my LAN. I have several IPs that I cannot associate hardware devices for. For example, 192.168.0.18, is pingable, and I can see the MAC address for it. If I ...
- Feb 25, 2022
In theory yes, in reality they sometimes get swept away. Often during a firmware update and certainly during a firmware default reset.
That is why you keep a list of MAC addresses and device names.
Kitsap
Feb 25, 2022Master
For the specific example you provided the screen snip for, it appears to be an Android device. Somewhere within range of your Wi-Fi there is an Android device connected to your Wi-Fi.
On the Android device itself, you can go to Settings -> About -> Status and the Wi-Fi MAC address will be shown. If it matches up with what was on your router, you have your connection.
Not sure how crowded your device environment is, I always keep a list of the MAC addresses of the devices I have in my home.
- rkruzFeb 25, 2022Apprentice
If a device is DHCP, does the device information that I enter into "attached devices" remain if the IP address is changed by the router?
- KitsapFeb 25, 2022Master
- rkruzFeb 26, 2022Apprentice
ok. thanks all. Its a big puzzle that Ill slowly work through.
