maniqwils
Dec 01, 2021Follower
How is the NETGEAR Nighthawk AC2600 Smart WiFi Router (R7450) compared to the TP-Link AC1900 A9?
Hello! I'm upgrading my default Spectrum router right now in my 1200 sq ft. home. The router is in the living room and in the next room I play a lot of games and stream bluray rips. How do these t...
michaelkenward
Dec 02, 2021Guru - Experienced User
You can get the technical details of the R7450 in the support section here.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for the hardware.
You can also check up on the R7450 with a local search.
Search - NETGEAR Communities – R7450
Be warned, people turn up there with problems, not praise.
Perhaps there is a TP-Link equivalent of this place.
