Dmac690
Jan 19, 2022Follower
how make WIFI without internet
I have a ac750. R6020 wifi router. and i need to set a wifi without using the internet. I need it to connect my ipad to an Allen & Heath QU-16 mixer, so i can mix the band remotely. we do not n...
michaelkenward
Jan 20, 2022Guru - Experienced User
Try this:
How many clients can you connect wirelessly to a NETGEAR router? | Answer | NETGEAR Support
and
How many devices can my Orbi system support? | Answer | NETGEAR Support
The R6020 is basic router, probably the bottom of the Netgear range.
According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware. This may not matter to you, but be warned that it will hobble you if you ever sign up for faster Internet. It also slows down whatever is going on in your local network. Newer devices support 1000BASE-TX.
