BeWill57
Jan 31, 2022Aspirant
How many devices can R7960P support?
My R7960P connects to the internet, but I have lots of drops of my internet connection, different devices (iPad, Intel Laptop). Distance from router does not matter, three feet or 50 feet with wall b...
Feb 01, 2022Guru - Experienced User
How many devices in total do you have connected all at once?
What channels are you using?
BeWill57
Mar 17, 2022Aspirant
Hi FURRYe38
Number of devices 24 - 34 devices.
Firmware Version V1.4.2.84_1.3.42
Showing 6 Neighbors or available wireless networks, broadcasting SSID
Spectrum is the current provider, but I had the same problem with AT&T
Modem Manufacturer Technicolor Model E31T2V1
Channels
2.4GHz set to auto
5.1GHZ set to 44
5.2GHZ set to 153
- FURRYe38Mar 18, 2022Guru - Experienced User
You should be fine...
