Biyahero
Feb 13, 2021Apprentice
How many devices would be necessary to benefit from tri-band
I understand the marketing of the Tri-Band systems vs the Dual Band Systems emphasizes the third band is used for "backhaul" and decongests the 5 Ghz band to be used for devices. However I wond...
- Feb 14, 2021
Biyahero wrote:
However I wonder how many devices would be necessary before you would see the benefits of the extra 5 Ghz Channel?
It isn't so much a "number of devices" thing. Tri-Band wifi is designed to be faster even with a single device.
What is a Tri-Band WiFi System? – NETGEAR Connection Blog
Biyahero wrote:
I can't forsee having more than 20 devices in our household which would be turned on at the same time ...
That's what I thought. Then I started getting all sorts of Internet of Things (IoT) bits and pieces that use wifi.
michaelkenward
Feb 14, 2021Guru - Experienced User
Biyahero
Feb 18, 2021Apprentice
michaelkenward wrote:
It isn't so much a "number of devices" thing. Tri-Band wifi is designed to be faster even with a single device.What is a Tri-Band WiFi System? – NETGEAR Connection Blog
Thanks for your comments and insights michaelkenward !
I decided to go with the Orbi Mesh RBK753S-100NAS for the reasons you mentioned. It is more expensive but at least I will have less chance of being disappointed.
In the end being satisfied with the performance is preferable to saving some money and being disappointd and mad later.
- michaelkenwardFeb 19, 2021Guru - Experienced User
Orbi is a good option for people who want decent wifi that is easily set up.
- BiyaheroFeb 19, 2021Apprentice
michaelkenward wrote:Orbi is a good option for people who want decent wifi that is easily set up.
Thanks! That is me.
