Biyahero
Feb 13, 2021Apprentice
How many devices would be necessary to benefit from tri-band
I understand the marketing of the Tri-Band systems vs the Dual Band Systems emphasizes the third band is used for "backhaul" and decongests the 5 Ghz band to be used for devices. However I wond...
- Feb 14, 2021
Biyahero wrote:
However I wonder how many devices would be necessary before you would see the benefits of the extra 5 Ghz Channel?
It isn't so much a "number of devices" thing. Tri-Band wifi is designed to be faster even with a single device.
What is a Tri-Band WiFi System? – NETGEAR Connection Blog
Biyahero wrote:
I can't forsee having more than 20 devices in our household which would be turned on at the same time ...
That's what I thought. Then I started getting all sorts of Internet of Things (IoT) bits and pieces that use wifi.
Biyahero
Feb 18, 2021Apprentice
michaelkenward wrote:
It isn't so much a "number of devices" thing. Tri-Band wifi is designed to be faster even with a single device.What is a Tri-Band WiFi System? – NETGEAR Connection Blog
Thanks for your comments and insights michaelkenward !
I decided to go with the Orbi Mesh RBK753S-100NAS for the reasons you mentioned. It is more expensive but at least I will have less chance of being disappointed.
In the end being satisfied with the performance is preferable to saving some money and being disappointd and mad later.
michaelkenward
Feb 19, 2021Guru - Experienced User
Orbi is a good option for people who want decent wifi that is easily set up.
- BiyaheroFeb 19, 2021Apprentice
michaelkenward wrote:Orbi is a good option for people who want decent wifi that is easily set up.
Thanks! That is me.
