MHCLV941
Jul 07, 2023Aspirant
How many simultaneous WIRED connections on NetGear R6700v3?
How many simultaneous WIRED connections will a Nighthawk AC1750/R6700v3 support? Wi-Fi is disabled so there are no wireless connections. I have found an article that says the device should ha...
- Jul 10, 2023Undoubtedly, the number of concurrent NAT sessions is limited ,- before the garbage collection does jump in.
Unfortunately, Netgear does not provide any specs on this subject, neither for their consumer routers nor for what is offered into the SMB market.
At some point, previously established NAT sessions will be closed for saving resources.
Looks like Netgear shareholders do see this as a trade secret - not worth to be documented. Needless to say: This isn't connection (LAN vsm Wi-Fi) related.
microchip8
Jul 07, 2023Master
In the hundereds, assuming your DHCP pool is wide enough if each one of it needs an IP.
MHCLV941
With all due respect, I doubt seriously that the only limitation is the number of addresses in the DHCP pool and/or assigned via DHCP reservation and/or hard-assigned on individual devices. The machines have more to do than simply request an address via DHCP.
Do you have any more realistic numbers, ideally backed up with some documentation or other authoritative source?
