Danne_V's avatar
Danne_V
How set fixed IP addresses for devices?
Hi! It's a small home network, 6-8 various devices. How can I assign fixed IP addresses to each of them? Using the Netgear Genie (Mac OS X). Or are there other ways?   Cheers, Dan
  • antinode's avatar
    Feb 03, 2018
       I don't use any Genie apps, only the plain-old web-browser interface,
    where what you want should be under ADVANCED > Setup > LAN Setup :
    Address Reservation.  For details, visit http://netgear.com/support ,
    put in your model number, and look for Documentation.  Get the User
    Manual.  Look for "Reserve LAN IP Addresses".
