koki0099
Aug 24, 2022Aspirant
How should I resolve the cause of 2.4GHz wifi not activating on Nighthawk X10 R9000?
Router Model: Nighthawk X10 R9000 (02/2021~) Firmware: v1.0.5.42 Hello. I can't find 2.4GHz wifi on my R9000. 5.0GHz wifi comes on and off and is unstable. The light is off at 2.4 GHz and ...
Kitsap
Aug 24, 2022Master
Before I declared the hardware dead, I would go check out Voxel's firmware for the R9000. Basically Netgear factory firmware with some polish.
Be sure and review the read me file on the Voxel download site.
Here is the thread over on Small Net Builders: https://www.snbforums.com/threads/custom-firmware-build-for-r9000-r8900-v-1-0-4-63hf.80444/ The download website URL is in the change log post.
- koki0099Aug 25, 2022Aspirant
Thank you for your mention.
I try it.
I cannot see and select 2.4Ghz wifi on my PC.
The LED is also turned off. I have tried rebooting the router and pressing the wifi on/off buttton, but the symptoms have not been resolved.
- KitsapAug 25, 2022Master
Can you log in to the GUI to make changes to your router settings?
If yes, go to Basic -> Wireless Settings. On that page there are check boxes to enable each of the wireless radios. One for 2.4 GHz and one for 5 GHz. Make sure they are both checked. If they are grayed out, press the wireless on/off LED switch on the top of your router (press and hold for at least two seconds then release). Rebooting the router will not change the state of the on/off LED.
