koki0099
Aug 24, 2022Aspirant
How should I resolve the cause of 2.4GHz wifi not activating on Nighthawk X10 R9000?
Router Model: Nighthawk X10 R9000 (02/2021~) Firmware: v1.0.5.42 Hello. I can't find 2.4GHz wifi on my R9000. 5.0GHz wifi comes on and off and is unstable. The light is off at 2.4 GHz and ...
koki0099
Aug 25, 2022Aspirant
Thank you for your mention.
I try it.
I cannot see and select 2.4Ghz wifi on my PC.
The LED is also turned off. I have tried rebooting the router and pressing the wifi on/off buttton, but the symptoms have not been resolved.
Kitsap
Aug 25, 2022Master
Can you log in to the GUI to make changes to your router settings?
If yes, go to Basic -> Wireless Settings. On that page there are check boxes to enable each of the wireless radios. One for 2.4 GHz and one for 5 GHz. Make sure they are both checked. If they are grayed out, press the wireless on/off LED switch on the top of your router (press and hold for at least two seconds then release). Rebooting the router will not change the state of the on/off LED.
- koki0099Aug 26, 2022Aspirant
I update firmware from the latest version to Voxel's one.
I also check it and try to press the wireless on/off LED switch.
But This problem doesn't be solved.
- michaelkenwardAug 26, 2022Guru - Experienced User
If you have problems with Voxel, ask them.
In your case, Kitsap suggested that as a way of ruling out dead hardware. Maybe that is the conclusion.
If that isn't it, you could revert to the stock firmware – Netgear doesn't support alternative firmware – and try answering some of the other questions you were asked (see above) before you went down that road.
- KitsapAug 26, 2022Master
koki0099 wrote:I update firmware from the latest version to Voxel's one.
Are you certain you know which one is the Wireless On/Off switch?
It is a combination indicator and switch. Press and hold for minimum two seconds and then release. See attached screen snip with the red arrow.
This is not a frivolous question.
Netgear's buttons confuse people who turn up here with that button "off" – cats and kids are among the suspects. They didn't realise that the LED is also a switch.
