galactica1951
Jan 30, 2023Aspirant
How to access and un-bridge a NETGEAR Nighthawk X6 Smart Wi-Fi Router (R8000)
I am ditching Spectrum. When I signed up I got Spectrum Router. I bridged the Nighthawk to the Spectrum Router to have extra Lan Ports. How do I un-bridge the Nighthawk? I cannot access the login...
michaelkenward
Jan 31, 2023Guru - Experienced User
galactica1951 wrote:
How do I un-bridge the Nighthawk? I cannot access the login into the Nighthawk as it takes me to the Spectrum Router.
As you are changing your network, a reset is probably the safest option. You will probably end up having to reconfigure the thing anyway.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
- galactica1951Jan 31, 2023Aspirant
I realize having two things chained together is not ideal. It worked to get extra Lan Ports. I did factory reset Nighthawk. Got rid of the Spectrum Wi-fi router and connected Nighthawk directly to modem. Even though the lower internet light is white on the Nighthawk, when I connect a computer to the Lan Ports.... they remain amber and I have no connection. When I try to go to a web page it brings me to Router Login. I cannot figure this out. This is not supposed to be hard. Thank you!
I have a Nighthawk R8000 and would like to connect to Spectrum Internet. Router is updated to latest version of firmware. Using Win11 PC with direct Ethernet Cable. Initially, using Spectrum Wi-fi router for more Lan ports. Chained Modem (Spectrum Model EN2251)
to Spectrum Router (ModelSAC2V1K) then to Nighthawk. When I connect Nighthawk directly to Spectrum Cable Modem there is no Ethernet Internet available. I would like to get a new Netgear Router, as the Nighthawk is 8 years old. First I want to see if I can connect. What am I doing wrong. Does Spectrum need a ID and password?
- michaelkenwardJan 31, 2023Guru - Experienced User
You plan to have modem > router > router?
Not sure what you mean by there is no Ethernet Internet available, but two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
I the sequence you describe, the best bet is to put the R8000 into access pount (AP) mode, wired to the primary router.But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
Only the version number can confirm that.
You might be surprised by how many "the latest" reports we see here that are no such thing. Sometimes by a large margin.
It depends on how you check. If you use one of the apps, or even the on-board check in the browser graphical user interface (GUI), it can get out of synch with the real world.
Then there are "hotfix" updates that have yet to migrate from the support library onto the update server, which is usually a day or two behind the library. That gives Netgear a bit of time to watch for reports of issues from the experienced users who keep an eye on the library.
More a case of a disaster waiting to happen than "not ideal".
Please read the links of provided, they should explain the symptoms that you describe and why you don't need to have two router chained together.
Let's start with this one:
You don't need the thing to be in router mode to get the LAN ports to work. A router in AP mode does the same thing.
Where are these "lower internet lights". They aren't on the R8000.
The LAN ports will remain amber if you connect them to a network with 100 Mbps ports. That's the whole idea. They are telling you the connection speed.
That's down to your unspecified computer
That is a classic "double NAT" symptom.
What web page are you going to?
This is not supposed to be hard. Thank you!It isn't if you follow the advice you were given. Do things logically and in the right order.
The white internet button is the second one from the bottom.
The LAN Ports are amber when a ethernet cable is attached - that does not mean they work. They blink when there is traffic.
I bridged one router.
Nighthawk X6 AC3200 Tri-Band WiFi Router Model R8000 is almost 9 years old. I purchase a Netgear Meah system from Amazon today. Time for a change. I am ditching the Spectrum Router.
See Diagram Below.
Thank you for your reply.
Terry
