Evynly
Mar 02, 2022Follower
How to access multiple netgear routers using internal reverse proxy
I have 3 netgear routers on my home network, all set up in AP mode on separate subnets. Accessing them via www.routerlogin.net doesn't work for me because a) all 3 try to use the same www.routerlogi...
Mar 02, 2022Guru - Experienced User
Just need to access them by using the IP address assigned to each of these routers while they are in AP mode.
Smart WiFi and Nighthawk series routers use routerlogin.net while Orbi series uses orbilogin.net
michaelkenward
Mar 03, 2022Guru - Experienced User
You can make life easier for future visits by giving each AP a fixed/reserved IP address. Then you won't have to track down the IP address every time.
Alternatively, install the desktop genie for your operating system and use the Network Map as a front end to reveal the current addresses.
